Crazy Homeless Guy Posted October 11, 2013 Share Posted October 11, 2013 Find out how to quickly troubleshoot and overcome some of many challenges involved inproduction! http://jamiecardoso-mentalray.blogspot.co.uk/2013/09/essential-tips-tricks-for-vray-and.html Hi Jamie, It might be useful to add this script to your post. Essentially Martin's idea but setup to work directly with Vray cameras. http://www.scriptspot.com/3ds-max/scripts/adjustrenderwidth-for-vray Link to comment Share on other sites More sharing options...
Jamie Cardoso Posted October 13, 2013 Author Share Posted October 13, 2013 (edited) Hi Travis, Thank you very much for your input here. It's much appreciated!!! Out of curiosity, have you tried the script you have suggested? I didn't post it in my blog simply because it doesn't extend the view in height! In addition, the field of view(FOV) also changes when tweaking with its width values...which defeats its whole purpose,in my humble opinion! The two scripts posted in my blog address all the above mentioned "bottlenecks", and converts a standard camera into a VRay camera. The entire process takes no time, and the user is NOT required to work out anything! I hope I am not missing anything!! Thank you again for weighing in on this post! Kind Regards Jamie Edited October 13, 2013 by Jamie Cardoso Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted October 14, 2013 Share Posted October 14, 2013 (edited) Out of curiosity, have you tried the script you have suggested? Yes, I have used it a handful of time. I didn't post it in my blog simply because it doesn't extend the view in height! True, the author does say that he is working on adding that. But Martin's vertical stretch appears to add pixels to the height in the Common Parameters rollout, which can be done by hand if needed. In addition, the field of view(FOV) also changes when tweaking with its width values...which defeats its whole purpose,in my humble opinion! I am fairly certain that Martins script changes the FOV as well. EDIT: Look up Martin's script on Scriptspot. Someone modified his original script to work directly with Vray cameras. Edited October 14, 2013 by Crazy Homeless Guy Link to comment Share on other sites More sharing options...
Jamie Cardoso Posted October 15, 2013 Author Share Posted October 15, 2013 Hi Travis, Thank you again for input here!!! Yes, I will definitely have a look at this new version of "Overscan" for V-ray cameras. Sounds very interesting indeed!!! Thanks again Travis!! Jamie Link to comment Share on other sites More sharing options...
