nicolastoubia Posted January 25, 2014 Share Posted January 25, 2014 (edited) So.. Has this ever happened to anyone? What should I do to stop the computer shutting down/ overheating while rendering? Edit- while rendering the CPU reaches 70+ degrees Celsius ...then shutdowns after a while ...also usually the "normal" temperature when I'm not rendering is usually about 46 degrees Celsius ... Which could be a bit high .? Also I cleaned my fan and heat sink a little before and it did the same render without shutting down but now back to the same problem. Please see the attached picture which shows my computer specs briefly Edited January 27, 2014 by nicolastoubia Link to comment Share on other sites More sharing options...
numerobis Posted January 25, 2014 Share Posted January 25, 2014 a bit more information would be helpful... - brand/model or components if it is self build. How old is it? - you could read out your temps ( http://www.alcpu.com/CoreTemp/ ) - What are your ambient temps? Looking at your flag i suppose it is... very hot at the moment. - did you already check mounting and fan of the CPU cooler? Link to comment Share on other sites More sharing options...
nicolastoubia Posted January 27, 2014 Author Share Posted January 27, 2014 Thanks for your reply, please see above info , thanks Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted January 27, 2014 Share Posted January 27, 2014 What cooler are you using? I would believe the stock one. Should still be enough. Make sure the cooler is properly seated on the CPU, with a thin layer of thermal paste (TIM). If you think you need more cooling, try a Cooler Master 212 tower heatsink, or a 120mm closed water loop (CLC) like a Cooler Master or Corsair. Link to comment Share on other sites More sharing options...
