dseeley Posted February 25, 2014 Share Posted February 25, 2014 I'm having trouble with noise in a vray render when using a highly reflective material and hdri environment map. I like the look of the image but just can't eliminate the last of the crunchy reflection components in the attached image. Any advice? Thanks! Link to comment Share on other sites More sharing options...
dseeley Posted February 25, 2014 Author Share Posted February 25, 2014 Looks like the dropbox links aren't working - images attached instead. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted February 25, 2014 Share Posted February 25, 2014 Peter Guthrie covered something similar, at least what I think you mean by crunchy reflections. http://www.peterguthrie.net/blog/2012/02/hdri-lighting-glossy-reflections Link to comment Share on other sites More sharing options...
dseeley Posted February 25, 2014 Author Share Posted February 25, 2014 Hi thanks for your reply. Unfortunately no that does not help me. The issue I'm having is not pixelation but rather ultra high contrast on edges within reflections. The map multiplier is turned down to 0.7 so it's not blowout on the hdri. Link to comment Share on other sites More sharing options...
salvador Posted February 26, 2014 Share Posted February 26, 2014 Can hardly see what you mean, but you can try turning on Sub-pixel Mapping and Color Clamping in the V-Ray setup dialog. Link to comment Share on other sites More sharing options...
farhanburondkar Posted February 26, 2014 Share Posted February 26, 2014 pls ur mail id?? send me on farhanburondkar@gmail.com Link to comment Share on other sites More sharing options...
dseeley Posted March 2, 2014 Author Share Posted March 2, 2014 Thanks everyone. I was able to mostly eliminate the issue by changing the antialiasing settings from default to quadratic. This seems to address the issue of very high-contrast reflection edges. Link to comment Share on other sites More sharing options...
