Vray Physical Camera renders going crazy
manpreetjuneja
Each time i do a minor change in the setting, either the camera, or the sun or material.
The camera renders crazy. The model goes missing only the background color/map is rendered along with one odd element in the scene.
But then when i save the change and restart 3ds max and render again without changing any other setting the scene the render looks ok (render corresponds to the changes made).
I am going mad restarting 3ds max each time.
Please help. Attach is the crazy render image.
(Am I missing something while setting up the camera which refreshes the camera only on restarting max? as soon as i restart 3ds max the old setting works and renders all the elements in the scene.)
Thanks a lot for a prompt response.
I am using Vray advanced 2.40.03 (3ds max 2010 32bit, 3gb ram)
Attached is the result of render after i changed few things, restarted 3dmax and rendered the scene again.
But the problem still persists as now when i try to change any detail again ,Vray renders the background with the swimming pool water only. I am sure when i restart 3d max it will show correct output. :/ Same setting Vray render output.jpg
