Joe Luckett Posted August 11, 2015 Share Posted August 11, 2015 Hi, This doesn't happen all the time but occasionally get a problem after I've rendered and saved out my elements. I like to save out a brighter and darker pass to blend with the RGB in Photoshop. However sometimes the colour corrections bar disappears and the button to open it in the bottom left of the frame buffer doesn't do anything meaning I cant alter the curves, exposure etc. Has anyone else had this problem and is there a fix without restarting Max? Thanks Link to comment Share on other sites More sharing options...
thomascoote Posted August 12, 2015 Share Posted August 12, 2015 Hi, This doesn't happen all the time but occasionally get a problem after I've rendered and saved out my elements. I like to save out a brighter and darker pass to blend with the RGB in Photoshop. However sometimes the colour corrections bar disappears and the button to open it in the bottom left of the frame buffer doesn't do anything meaning I cant alter the curves, exposure etc. Has anyone else had this problem and is there a fix without restarting Max? Thanks That's a bug I've experienced a few times myself. Restarting Max only way I've found to fix it. Curious why you save out a brighter and darker pass? And if you're rendering as 32-bit can't you just duplicate your base layer, apply your corrections to each and then blend? Link to comment Share on other sites More sharing options...
Joe Luckett Posted August 12, 2015 Author Share Posted August 12, 2015 Fair enough, thanks anyway. There's no reason in particular, just something I do as part of my workflow and as you said I can do the exact same thing once it's in Photoshop so it's not really an issue. Just something that bugs me. Link to comment Share on other sites More sharing options...
NoodleLuff Posted August 12, 2015 Share Posted August 12, 2015 Hey Joe - without sticking my nose in too much, a simpler way to get the same result may be to use a curve (or other) adjustment layer in photoshop above the base render. This way, you just need to replace the base RGB layer when updating - you may find it streamlines your workflow a bit more. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted August 12, 2015 Share Posted August 12, 2015 It is not only the colour corrections bar that can disappear, the lens effect settings also has this problem. Ive yet to find a way to get it working again without restarting max. Link to comment Share on other sites More sharing options...
Morne Erasmus Posted August 18, 2015 Share Posted August 18, 2015 Saw it a lot in VRay 2.4 So far VRay 3.2 is fine Link to comment Share on other sites More sharing options...
rossjordan Posted September 1, 2015 Share Posted September 1, 2015 Hi, This doesn't happen all the time but occasionally get a problem after I've rendered and saved out my elements. I like to save out a brighter and darker pass to blend with the RGB in Photoshop. However sometimes the colour corrections bar disappears and the button to open it in the bottom left of the frame buffer doesn't do anything meaning I cant alter the curves, exposure etc. Has anyone else had this problem and is there a fix without restarting Max? Thanks I have also experienced a similar issue of the corrections bar disappearing. Its not the most convenient fix but I've found that unticking the button (i.e to hide the correction bar even though its not visible anyway) and then rendering out at a different output resolution will allow you to press the button again and see the corrections bar. As long as you're using history you shouldn't lose anything, as the resolution change refreshes the frame buffer. Again not the most convenient of solutions but quicker than restarting Max. Hope it helps Link to comment Share on other sites More sharing options...
