delphineschaack Posted February 18, 2016 Share Posted February 18, 2016 Studio/Institution: Deesys GGenre: Residential InteriorSoftware: 3ds max - vrayDescription: Hi everyone Here is my last job. Any suggestion to make this look more realistic? I m kinda stuck here. Something doesn't seem correct to me but I don't know what to change to make it look better. Thks a lot Link to comment Share on other sites More sharing options...
harryhirsch Posted February 18, 2016 Share Posted February 18, 2016 not bad... 4 black ceiling lamps and the 4 wooden things...too much for my taste the chair looks odd perhaps a bigger rug what is the use of these two white ''picture frames'' on the wall? Link to comment Share on other sites More sharing options...
waizen Posted February 18, 2016 Share Posted February 18, 2016 I agree with Harry about the "picture frames" thing, but that's just my personal taste. I keep wanting to psychologically put something into them. I also agree with Harry about the chair on the left. Seems too wide to me to feel like it would be comfortable. Besides that, the only small thing...and granted, it's a very small thing...is that the hot spot portion of the light being cast on the brick wall, just to the left of the clock seems a bit hot to me. At least it does on my monitor. Seriously, it's not a deal breaker of a thing. Other than that, If I was the client, I would be pleased. Nice work. Link to comment Share on other sites More sharing options...
godzycabari Posted February 18, 2016 Share Posted February 18, 2016 It's all the matter of taste, but i agree with what was said above, there is too many lamps, remove those slippers, drop some black and white abstract paintings or something in the frames, maybe change the texture on the yellow brick wall, it seems a bit weird to me, also play around with post-production since sometimes in most cases it makes a huge difference. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted February 18, 2016 Share Posted February 18, 2016 I am not an interior designer, but the comments above seem OK to me. Regarding composition tho the room seems like it is very big and all the furniture is pushed to that corner. When photographing rooms try to avoid looking down, keep your camera parallel to the ground or even looking up. if you can't frame your object then move the camera down, but in height not rotation.. I would move the camera down and closer to the couches, making the outside light traveling from left to right, with right side of the image being darker... ish. Adjusting the camera alone will make you feel inside the space and your eye won't that critical of reality or not. Link to comment Share on other sites More sharing options...
Andres Saarnak Posted February 19, 2016 Share Posted February 19, 2016 fco3d said: When photographing rooms try to avoid looking down, keep your camera parallel to the ground or even looking up. if you can't frame your object then move the camera down, but in height not rotation.. I would move the camera down and closer to the couches, making the outside light traveling from left to right, with right side of the image being darker... ish. Adjusting the camera alone will make you feel inside the space and your eye won't that critical of reality or not. This. Otherwise, it´s fine. Link to comment Share on other sites More sharing options...
