V-Ray adv 3.20.02 problems
luismacedo
Hey guys, I´m having a lot of trouble dealing with the new 3ds max 2016 VRay 3.20.02 combo and I´m really desperate for assistance. I worked with the previous versions of both, from 3ds Max 09 to 3ds Max 2014 and older versions of VRay and never had a problem (at least not big ones).
The thing is, I upgraded my software and hardware to finally be up to date. I´m running 3ds Max 2016 with VRay adv 3.20.02 on 12gb of dedicated graphics, 64gb of ram, i7 5960x processor.
The problem is that I CAN´T RENDER AT ALL with vray. Mental ray and iRay do render but somehow vray won´t. When I render something, It´ll show mostly an overexposed series of circles, kind of in a ripple effect way. I´m using a vray sun and a Physical Camera, also with vray materials and have been trying for days to get it to work but I can´t. I would be so grateful if you could help me out. I´ll attach the render.
Thanks in advance guys
  orinmacahdo said:
1 . Check you Vray installation re install it if needed
2. Make sure you are running the latest drivers
3. Try the same scene on a different computer.
4 . Update your DX
I tried everything, and it didn´t work. After lots of problems with V-Ray adv 3.20.02 and 3ds max 2016 I decided to just go back to the way I´m used to and Installed 3ds Max 2015 and everything runs smooth. I guess I´ll have to stick to what I´m used to but thanks anyway!
