tand Posted June 12, 2016 Share Posted June 12, 2016 Hi to all, Lately from friends and youtube videos I heard that Vray3.3 had a big improve in time saving and simplicity in the config, so I wanted to give it a try. I just installed it and opened a file that I used with vray 3.2, and when opening it asked to use the new features, so I said yes, that was the aim of the change. Surpirse though, it's really much slower than 3.2. Is there something I need to uncheck? I'm really susprised :S A file that lasted 3-4 min (just 600px, text file) now it lasted 25 min. Thanks a lot! Link to comment Share on other sites More sharing options...
Devin Johnston Posted June 13, 2016 Share Posted June 13, 2016 As with everything in Vray settings matter a lot, you need to look a the new settings in 3.3 and figure out what's changed from 3.2. If you want help you need to post what your old & new settings are so people can try and diagnose it. Link to comment Share on other sites More sharing options...
Guest dialog Posted June 17, 2016 Share Posted June 17, 2016 update to 3.40.01... much faster Link to comment Share on other sites More sharing options...
Matthieu Posted July 8, 2016 Share Posted July 8, 2016 Evening, I tested several versions of the releases the 3.30.04, and the 3.30.05 and i came back to the 3.20 cause it took ages to render, really slowler. Now i installed the 3.40.01 and after many tests its the same story...slower and i will come back again to 3.20. Everything was ok during the installation so its not that, its not about older scenes opened with a new version, maybe there's something to check or uncheck or something i missed. Does anybody got the same problem and maybe find a solution. Cheers Link to comment Share on other sites More sharing options...
