foresters Posted August 24, 2016 Share Posted August 24, 2016 hi, i use vray sun to light the scene , but it gives light brown light.i give material (vray diffuse 245,245,245)for the entire scene objects. i am using 3dsmax 2016 vray 3.30.04 Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted August 24, 2016 Share Posted August 24, 2016 https://docs.chaosgroup.com/display/VRAY3MAX/Sun+and+Sky+System+%7C+VRaySun And you should turn on and test exposures with a darker white value. Many suggest 180,180,180 for a softer white. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 25, 2016 Share Posted August 25, 2016 Because most of your light is coming from direct light (the sun) and not from diffuse/global illumination (the sky, which is blue). Adjust your white balance on the camera. Link to comment Share on other sites More sharing options...
foresters Posted August 25, 2016 Author Share Posted August 25, 2016 Thank you Link to comment Share on other sites More sharing options...
