noorbitar Posted September 9, 2016 Share Posted September 9, 2016 Hi, I have a project due tomorrow, and i am trying to render this animation in vray 3dmax, however, the rendered objects are all appearing black and only the hdri background image is being lit, I cannot find the problem! i went over the cam setting, vray sun, and materials, and the vray settings, however it does not seem to work!, im rendering the animation as single frames and then combining them in 3ds max ram player. can anyone give a solution ASAP please, I have attached the file. THANK YOU!!!! Link to comment Share on other sites More sharing options...
rajeshraj Posted September 9, 2016 Share Posted September 9, 2016 check your material(v-ray /mental-ray) type and render engine u r using ! Link to comment Share on other sites More sharing options...
Chris MacDonald Posted September 9, 2016 Share Posted September 9, 2016 How are we supposed to help without any screenshots of settings? Link to comment Share on other sites More sharing options...
John Dollus Posted September 9, 2016 Share Posted September 9, 2016 check to make sure the vray properties aren't set to matte for some reason. check the alpha channel of the image and verify it's solid white. check the native exposure settings in the Max environment to make sure it's set correctly. I expect it's an exposure issue. Link to comment Share on other sites More sharing options...
jimbuchanan1 Posted September 10, 2016 Share Posted September 10, 2016 Camera clipping turned on? Link to comment Share on other sites More sharing options...
pablovergara Posted September 10, 2016 Share Posted September 10, 2016 Were you able to fix it? Put a white material in the override slot and test Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
