steevenberube Posted October 13, 2016 Share Posted October 13, 2016 Hi ! So I have a vray dome with invisible ticked. I did everthing like I used to for the last couple years but somehow All of my new scene/project are now showing the background thru windows. It shows like 50% when i put it in photoshop. I mean I can slide a image on a layer behind and it will shows but 50-50 with the new image behind I have a VrayHDRi map in environment slot and the in dome. Vray dome with invisible alpha channel in Vray frame buffer seems alright I save as PNG with alpha channel tick Maybe I hit a shortcut or something? Can you help me thank you Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted October 14, 2016 Share Posted October 14, 2016 Why do you need it in your environment slot? It should show up in reflections anyway? Well anyways my guess is that is what you are seeing, the reflections of the sky on the glass surface. Link to comment Share on other sites More sharing options...
pandapooh Posted October 24, 2016 Share Posted October 24, 2016 Hi!. Select the dome Go to the modify panel Go to the tab that says "options" Deselect "Affect reflections" Link to comment Share on other sites More sharing options...
steevenberube Posted October 24, 2016 Author Share Posted October 24, 2016 (edited) Hi pandah pooh. Thanks for the reply. Unchecking Affect reflections did not work (as well as specular and diffuse). Here is an image so you can understand better. Its .png and I added a black square with dot line behind the image. https://postimg.org/image/r80sa0kud/ Any clue with it could be? Thank you Edited October 24, 2016 by steevenberube Link to comment Share on other sites More sharing options...
