Vray lightSelect render element doesn't show light when glass appears in between vray
ashishchakravarty
In 3ds max when i set vray material's Refraction parameter's Affect channels to "Color only" Vray LightSelect render element does not show light which comes through glass. But when i set to "All channels" i can see the lights in Vray LightSelect render element which is coming through glass.
But the problem is that i can not set Refraction parameter's Affect channels to "All channels" in 3ds max because Vray Refraction render elements does not match to beauty pass with Linear Dodge (Add) blending mode in photoshop, it only matches when i set material's refraction parameter's Affect channels to "Color only".
