ossamachaabane Posted May 23, 2017 Share Posted May 23, 2017 Hello there This is my first time I try vray with 3ds max. I created a new Vray material (a white marble texture). But the texture doesn't appear neither on the viewport or the render. this is what I get : (it's just the color that changed , there is no texture) Please help ! Thanks Link to comment Share on other sites More sharing options...
dylanlester1 Posted May 23, 2017 Share Posted May 23, 2017 Hello there This is my first time I try vray with 3ds max. I created a new Vray material (a white marble texture). But the texture doesn't appear neither on the viewport or the render. this is what I get : (it's just the color that changed , there is no texture) Please help ! Thanks You created the material, but did you apply it to your object? You need to drag it onto your object or apply to selection from the material editor. To view the material in the viewport you hit the 'show in viewport' button from the material editor... Link to comment Share on other sites More sharing options...
ossamachaabane Posted May 23, 2017 Author Share Posted May 23, 2017 Yes , I did apply the material Link to comment Share on other sites More sharing options...
dylanlester1 Posted May 23, 2017 Share Posted May 23, 2017 Ok, have you applied a UV map modifier? Link to comment Share on other sites More sharing options...
ossamachaabane Posted May 23, 2017 Author Share Posted May 23, 2017 Thank you Dylan Lester. Problem solved Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 23, 2017 Share Posted May 23, 2017 Hello there This is my first time I try vray with 3ds max. I created a new Vray material (a white marble texture). But the texture doesn't appear neither on the viewport or the render. this is what I get : (it's just the color that changed , there is no texture) Please help ! Thanks Have you read the manual. Link to comment Share on other sites More sharing options...
