major viewport error!!!
diuvermoya
Hi, I need urgent help, I´ve been having this very big problem with my 3ds max since version 2016, now with the 2018 version is the same and I don´t know why this is happening. I´ve been trying anything you can imagine but nothing works. I´ve already upgraded everything to the latest version, everything but Windows, and it´s happening on every machine that I use, it is like the file gets corrupted once it happens.
The point is that when I hit any object in the scenes, suddenly the gizmo or the UCS going very far, the pivot point of the scene loses, then I have to switch viewports and press Z to get to the center of the model, this doesn´t happen when I look through a camera. Just now, I´ve added a vray proxy and it doesn´t happens. I don´t know what to think. I´ve tried to attached a video but I can´t do it.
I need urgent help please, I´m in the middle of something important!
Thanks in advance.
Hello Nicolai Bongard, thanks for your reply, I asked also on Autodesk forums (with a video demonstration) and solved my problem. It was a Viewcube or System Units issue or both. I´ll let the link to that post so maybe it could help others as well. To me was very helpful and again, it solved my problem, the most important.
I hope you find it useful too.
https://forums.autodesk.com/t5/3ds-max-forum/3ds-max-viewport-error/m-p/7320555#M143939
Thanks again!!!
