Guest danielaldarian Posted November 18, 2017 Share Posted November 18, 2017 Hello everyone! First post here. I hope this is the right place. I am looking for the software (or any alternative) which was used to make the first 15 seconds of this YouTube video: I'm a 3D Designer by profession, working on a digitalization project of a certain medieval castle in 3D. The castle is almost ready (but I also have to show a "timelapse" of the 3D modelling, preferably in the style of the aforementioned YouTube video. I've been looking everywhere but so far I'm unable to find anything similar. Any comments would be much appreciated. Thank you in advance! Link to comment Share on other sites More sharing options...
James Vella Posted November 26, 2017 Share Posted November 26, 2017 if you were to do this in 3dsmax you would apply a wireframe shader to the model and then animate a slice modifier moving up from the ground. Im sure you could do the same in any other software that has a similar toolset. Link to comment Share on other sites More sharing options...
Guest danielaldarian Posted November 26, 2017 Share Posted November 26, 2017 Thanks for the reply James! You're right. The Slice Modifier seems to be similar to the Section Plane in SketchUp (I'm a SketchUpper). And how would you go about the floorplan? Before the building "rises" in the animation, you can see as if someone "draws" the floorplan lines. But since the floorplan technically is on a flat plane, the lines would all appear at the same second, if you used Slice or Section Plane, wouldn't they? Link to comment Share on other sites More sharing options...
James Vella Posted November 26, 2017 Share Posted November 26, 2017 looks like in this case they have done it quite simply with parts of each line appearing per frame (they have broken 1 line into 3-5 pieces). In 3dsmax you could further this affect animating a follow path modifier or extrude along path - I think I found something similar for sketchup below (hopefully you can keyframe this). The best looking outcome I can think of would be outputting the splines as .ai files or something similar and then using trapcode 3d stroke in after effects Sketchup extrude along path eg. Trapcode 3D Stroke example eg. Link to comment Share on other sites More sharing options...
Guest danielaldarian Posted November 26, 2017 Share Posted November 26, 2017 Thanks again for the information and links! Been struggling with this for months! Finally getting somewhere. I liked the Trapcode a lot. Deep down I felt that After Effects would have a certain play in this, haha! Now I seem to know where to start. Thank you! You saved me more months of frustration and confusion. Link to comment Share on other sites More sharing options...
James Vella Posted November 27, 2017 Share Posted November 27, 2017 glad to help Daniel, If you have any questions dont hesitate to ask. Link to comment Share on other sites More sharing options...
