Jamie Cardoso Posted May 30, 2018 Share Posted May 30, 2018 Check out this new tutorial on how to control the depth of field effect in Photoshop or AE, using a depth map from Vray This short video tutorial takes users through the quick process of adding and tweaking the dof in post production, using Photoshop. http://jamiecardoso-mentalray.blogspot.com/2018/05/dof-control-depth-of-field-effect-in.html Using the dof (depth of field) directly in your 3d scene can at times be irreversible, when faced with a tight deadline. However, using a depth map (e.g. vrayzdepth, etc ) in post (Photoshop or After Effects) will provide you with the ultimate control to rectify any potential tweaks that might arise from last minute changes from a client. I hope you like it, and leave your comments below. Ta J Link to comment Share on other sites More sharing options...
