jeneetan Posted October 8, 2018 Share Posted October 8, 2018 Hello, I'm using Vray 2.0 in Sketch Up 2015 and when I render this particular scene, the progress bar stucks up as well as the bucket. Every time I repeat it, the bucket stucks at the same spot. I almost waited half day but nothing happens. I don't know if its because the file is too heavy but it won't finish the render. I hope somebody can help me. Thank you! Please see image attached. Link to comment Share on other sites More sharing options...
eduardasvuskvariokas Posted October 8, 2018 Share Posted October 8, 2018 While this isn't going to be much of help, but it seems like it's stuck on rug. Most likely some displacement or hair system was used to create that one. Maybe the load is too much while trying to calculate that on an already heavy scene. Have you tried removing the rug and see if the thing works? Just an idea, hope someone with better advice will show up soon Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted October 8, 2018 Share Posted October 8, 2018 We need more information regarding your scene, render settings, material setup. as @Eduardas mentioned it may be the rug if you are using displacement or fur. You may be running out of memory because of that. But again without more information, it is hard to tell. Link to comment Share on other sites More sharing options...
jeneetan Posted October 9, 2018 Author Share Posted October 9, 2018 Thank you for the replies! Somehow when I change the angle of the scene and zoom it out a little bit, it finishes the render. I also tried removing the rug within the same scene but same thing happens. It's just with this particular angle I don't know why it won't finish the render. Link to comment Share on other sites More sharing options...
