MAX Tools Posted August 4, 2021 Share Posted August 4, 2021 (edited) Hello all! Our team is pleased to present and recommend for use the plugin "V-TayMtl Converter 3", which, in addition to converting materials, lights, cameras, proxies and other scene components, can now also automatically adjust the workspace in ACEScg or sRGB for rendering in V-Ray! This corresponding function does the following: depending on the option selected, switches to ACEScg or sRGB in the [Render Setup> Settings> Color management> Rendering RGB primaries] finds all VRayBitmap and VRayColor maps in the current scene and determines the purpose of these maps - displayed in color (diffuse (albedo), reflect, refract, translucent, sss, selfillum, environment/light etc.) or with technical data (bump, glossiness, displacement, ior, anisotropy etc.) and separates the map instances (if any) in the conflicting slots. toggles the [RGB colorspace] and [Color space transfer function] maps according to the selected color space. In this case, the function determines whether a bitmap texture with special suffixes in the file name (_lin_srgb, _srgb, _acescg, _raw) is used or the file name is used without a suffix. optionally, you can enable gamma correction in [Render Setup> V-Ray> Color mapping] and rename duplicate map names that may be after splitting instances in conflicting slots. "V-RayMtl Converter 3" allows you to switch to the desired Color Space with one click! You can read more detailed information about this plugin here: "V-RayMtl Converter 3" Official site or here: ScriptSpot "V-RayMtl Converter 3" are officially tested by the Autodesk® team and also is available in the Autodesk® App Store. Good luck and great creative work! Best regards, MAXTools team. Edited August 4, 2021 by MAX Tools change text Link to comment Share on other sites More sharing options...
