fadi3d Posted April 28, 2009 Share Posted April 28, 2009 hello everybody, this is driving me crasy i was working on an interior scene (max 2009 Vray sp2) i have 101,854 polys (88,023 verts) and when i noticed the file is taking too much time to save i checked the size it was (491,776 KB) and the previous file was a mere 61.235 KB i did not add much polygons and i used the garbage collector which gives me in the maxscript listener 1693536L ???? and no use i don't want to go back to where i've started so please help thanks in advance Link to comment Share on other sites More sharing options...
videep Posted April 28, 2009 Share Posted April 28, 2009 hey... Heard such a problem for the first time.. though... if u follow the extension, u get the backup files.... My documents>3dsmax>autoback This is the default place for max files.Approx 3 files are saved. Please check all... One may be the one u are looking for. Link to comment Share on other sites More sharing options...
vizfx Posted April 28, 2009 Share Posted April 28, 2009 customize/prefferences, files tab and mark "compress on save" Link to comment Share on other sites More sharing options...
BrianKitts Posted April 28, 2009 Share Posted April 28, 2009 vizfx said: customize/prefferences, files tab and mark "compress on save" That was my first thought..... If that doesn't work, select just objects in your scene and do a "save selected" to dump them out to a new file. Check that file and see what the file size is, if that's normal then you must have some hidden/bad geometry eating up your file size. Link to comment Share on other sites More sharing options...
fadi3d Posted April 29, 2009 Author Share Posted April 29, 2009 thank u all for ur suggestion nothing worked so far and brian i did reset and merge the objects with no luck it is truly driving me crazy i hope someone has a solution Link to comment Share on other sites More sharing options...
amer abidi Posted April 29, 2009 Share Posted April 29, 2009 I find that merging objects into a new scene is fa more efficient than "save selected", since it doesnt save many sometimes unneccesary info accompanying the objects (materials in material editor, environment settings, etc..) 1- Go to your render dialogue, bottom of the dialogue, select presets, and save your render presets. 2- reset and start a new file, load the render settings you just saved. 3- Start meging objects, starting with the ones you created first, saving incrementally to different filenames (file01.max, file02.max, etc..) 4- The more objects you add, the bigger the file will get, up until you see that gigantic leap in file size, you'll be able to figure out the culprit. It's the only way around this that i see. I recently had a 16mb file jump to 230mb only after animating a few characters with biped footsteps! but when i figured out that they were causing the problem, i saved out the animation ifo to point cache and merged into a new file. File, with animated characters, went back to 16mb. Link to comment Share on other sites More sharing options...
fadi3d Posted April 30, 2009 Author Share Posted April 30, 2009 hello dear friends, thank u all for ur help the truth is i'm not sure what happened but i Chose file NEW and keep objects (but not hierarchy) and saved and the file droped to 14000 KB (i hope this will help somebody in the future) once agai thank u all and take care ur the greatest forum ever. Cheers. Link to comment Share on other sites More sharing options...
clauco Posted February 7, 2010 Share Posted February 7, 2010 YEAH! it works! many many thanks fadi! Link to comment Share on other sites More sharing options...
padre.ayuso Posted February 9, 2010 Share Posted February 9, 2010 Here is another one in case it happens to any of you. Call it a "max virus" or call it a bug on the system, or call it what you will, but one thing you can check is "Motion Mixer" under "Graph Editors". If this file is full of lines and you have not done anything with it, your file is, what we call in our office "blotted". We found at one time, many years ago, a script that will handle it that is called "Motion Mixer Cleanse". Not sure where to find it, but I have it attached here. Hope that helps to anyone that runs into this problem. Best Link to comment Share on other sites More sharing options...
Tigrelab Posted April 9, 2010 Share Posted April 9, 2010 You just have saved my life with your script, want to give you a big hug!!!! Link to comment Share on other sites More sharing options...
Jesper Pedersen Posted May 29, 2010 Share Posted May 29, 2010 Just found this thread. Thanks a million, our file would grow incrementally on each save ..last one was 500MB for what should have been about 12MB ! Link to comment Share on other sites More sharing options...
offf Posted June 27, 2010 Share Posted June 27, 2010 GENIOUS!!!!!! NEW FILE ( WITHOUT HIERARCHY) and WORKS Thanks a lot 404MB instead of 3,4MB! Crazy , craazy. Thanks a lot people! PS thanks as well for the scriipt! Link to comment Share on other sites More sharing options...
soe Posted July 15, 2010 Share Posted July 15, 2010 Thank you very much for your script.. Link to comment Share on other sites More sharing options...
snorkulencija Posted July 20, 2010 Share Posted July 20, 2010 File -> New -> Keep objects (without hiararchy) THANK YOU MAN, you saved my day (and deadline )!!! Link to comment Share on other sites More sharing options...
stevnhog Posted July 25, 2010 Share Posted July 25, 2010 hi i have same problem. i am new with 3ds max can you tell me how to install script. Link to comment Share on other sites More sharing options...
padre.ayuso Posted July 25, 2010 Share Posted July 25, 2010 You just need to put it where the rest of your scripts are and then run it from 3DS Max. Go to MaxScript, then click on Run Script and a window opens with all of your scripts. Copy the script in that folder then double click on it and it will run by itself. Easy going. Link to comment Share on other sites More sharing options...
fpcamp Posted November 10, 2010 Share Posted November 10, 2010 Keep objects (without hierarchy)... saved my day! Thanks everyone! My last file was 260MB very, very large, and when I made new small changes the file jumped to 600MB and then I saved as again and then jump to 1.250GB! no chance to work on it.. Now, after File -> New -> Keep objects (without hierarchy) the the file is 32 MB !!!!!! Unbelievable!! Maybe the several groups that I was using at the scene was causing it .... when you open a new file, without any hierarchy you lose all groups. Link to comment Share on other sites More sharing options...
theqball Posted November 11, 2010 Share Posted November 11, 2010 The ballooning file issue with mixer tracks was fixed in the 2009 release. However, files that already have this problem will not be corrected. So if a file was created before the 2009 release and then subsequently saved in a later release it will still contain the bloated tracks. To clean this file you can use the attached maxscript. If you are able to reproduce this problem on a more recent release please submit before and after files along with detialed repro steps here: http://www.autodesk.com/3dsmax-DefectSubmission Link to comment Share on other sites More sharing options...
sharon1 Posted November 25, 2010 Share Posted November 25, 2010 Thank you very much! Link to comment Share on other sites More sharing options...
pitt0413 Posted January 2, 2011 Share Posted January 2, 2011 Thank you very much!~~~~l am so happy now~thank again Link to comment Share on other sites More sharing options...
calilmal Posted January 6, 2011 Share Posted January 6, 2011 hey everyone, i'm having a similar problem, however it's not so much annoying when it comes to the saved file size, as to the ram it uses when opened cause i cannot render the scene... i'va managed to reduce the scene size to 100mb from the 400mb, yet still it opens very slow and uses approx. 3gb of the total 4gb ram i have... i cannot import/merge objects nor render the scene cause it crashes... the scene itself is not too complex, and similar ones used to use about 500mb of memory while opened and max. 1,5gb on rendering... i have no idea what could have happened, could it be a problem with the software itself? i'm using max 2011 32bit, which - by the way - 2 days ago started to load much slower than before. the file saving time is also odd - it can take even 5-10min to save... :/ i'd appreciate any help... thanx Link to comment Share on other sites More sharing options...
theqball Posted January 6, 2011 Share Posted January 6, 2011 loading Max 2011 itself will use upwards of 500mb of RAM, plus the OS will usually hold close to 1GB these days on a system for everyday use and not stripped clean for production. Add to all that a 32bit OS has a limitation of 2GB of addressable space per application. I would highly recommend upgrading to a 64bit OS and the 64bit version of Max. Link to comment Share on other sites More sharing options...
calilmal Posted January 16, 2011 Share Posted January 16, 2011 Well, I am using the 64bit versions - both the software and the system. I've managed to solve the filesize and the used RAM amount problem. And now I'm stuck with the application hangs when traying to save the file (or on auto-save). The files of about 20MB size with a simple scene (and about 7MB compressed on save) are taking more than 8hrs to save! I don't think anyone has time for that :/ I did try few times to leave it on for the night and it ended up saved after all, but few times it did stuck for good... Reinstallation didn't help and the error is AppHangB1... There is no other geometry or materials, nor the settings, which I haven't used before and everything was fine. It's just like the programm decided suddenly one day to make my life a hell... :/ Link to comment Share on other sites More sharing options...
designm8or Posted January 17, 2011 Share Posted January 17, 2011 thank you man very very very much ,,, you have just saved my life with this script .. i really was going mad because of this problem . Link to comment Share on other sites More sharing options...
bronius Posted April 7, 2011 Share Posted April 7, 2011 (edited) I have same problem when MAX save files 4-5 minutes. Both scripts (padre.ayuso's Motion Mixer Cleanse.zip and theqball's RemoveMixerReftargs_.zip) do nothing. Just nothing! In Dope Sheet are LOT of note tracks, but both scripts can't clean them. BTW, I use MAX 2011 Design, Win7 64 bit. Maybe scripts can't run on MAX 2011? P.S. davistalexander's script helped to me. Many thanks! Edited April 7, 2011 by bronius Link to comment Share on other sites More sharing options...
