xEndlessxUrbiax Posted April 17, 2012 Share Posted April 17, 2012 We are currently upgrading all the machines in our office and I am trying to make sure we'll be able to have an operating render farm for use when everyone goes home in the evening. I've done some research on Backburner and setting up the server and everything looks doable and clean. I plan on doing two kinds of outputs when the render farm is available. Animations, and high quality renderings. I will be using Mental Ray for the animations as iRay is unbiased and not really ideal for animations. However, I like to use iRay for my renderings and I was hoping I could use the farm for iRay. I looked in the render setup under the commons tab for the icon that says "Net Render" which apparently lets me use Backburner for the task. Under the iRay rendered, this icon does not exist. Does this mean I can't use Backburner to help render out my iRay rendering? I was hoping to have the computers work on different segments of the image using the "Split Scan Lines" option in Backburner. Thanks for any input Link to comment Share on other sites More sharing options...
John Dollus Posted April 18, 2012 Share Posted April 18, 2012 the current version of iray does not seem to support split scanlines. Each network node will have to render a full frame based on it's own hardware resources. You should be able to submit your scene to backburner once iRay is setup as your renderer though Link to comment Share on other sites More sharing options...
