Vray + Multiscatter + Max Crashing During Render
theeastcoastwest
Hello,
I have been having a seriously annoying issue with the Multiscatter plugin as of late. Relatively small scene without too many scatter objects.
Vray 2 updated.
Max 2012
Multiscatter 1.1.xx (on a different machine can't remember specific release)
Vray memory set to dynamic @ 10000 gb
All Materials Vray.
Intel chipset
12gb ram
ati graphics
So, the problem is during light cache calculation, max just crashes completely. The scene is roughly 550k polys, which is on the low side for what my machine usually is handling. I am using MS to scatter 1 bunch of grass, and one unique tree. So after my scene was crashing, I exported just my house model out and started anew. Grass scattered on simple plane, I'm just testing some new models, and set to max 100,000 instances.
It was rendering fine, then I added in the tree to another plane and it started crashing. I also had 1 other unique tree in the scene at this point, but it was not being scattered. I set the tree that I was scattering to have a max of 35 instances. CRASH.
I re-opened the scene and deleted everything except the original plane and grass scatter objects, that was rendering successfully, and it still crashed.
I cannot for my life figure out why it is crashing, and especially what I am doing that makes a scene that was rendering fine at the beginning, start crashing max.
Anyone have any ideas?
I am strongly considering just going with another scatter plugin.
  • 1 month later...
Light Cache is very fast algorithm, but there are some drawbacks. Light Cache needs much more RAM than other V-Ray GI algorithms. MultiScatter is tool for creating huge amount of geometries which also needs RAM.
therefore there is a big chance to encounter problems (very slow rendering or crashing) when you use LC with MultiScatter.
So using Light Cache in exterior visualisation consumes lots of memory wherever you are using MultiScatter or not,
and its just our very general recommendation not to use it, unless you really know what you are doing and have tons of memory.
Thanks for the advice. I wasn't really aware that light cache used such a larger amount of Ram compared to other GI solutions.
I figured out the problem though, and it wasn't a memory issue.
Multiscatter can't handle normal maps in the bump slot for some reason? Regular maps work fine in there. Some of the models I was scattering were using normal maps in the bump slots.
Cooking with grease now though!
Basically speaking, it may render fine with small CPU or RAM errors, which may be unnoticed when rendering a single object, but when you multiply it thousands or millions times with MultiScatter that problem will just grow exponentially and crush the system
  • 7 months later...
