hoseinasadi Posted December 19, 2013 Share Posted December 19, 2013 hey guyz, ive been trying to apply a wet to look to my texture, took the texture into PS and painted few areas in white/light grey so they'd appear wet. however after i get a render the white/light grey areas appear as dark spots over my texture. here's a photo to illustrate what i mean. any idea what i might be doing wrong? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted December 19, 2013 Share Posted December 19, 2013 Well VRay is energy conserving; the more reflective a surface is, the less diffuse value it has. You need something for it to reflect, rather than just black. Link to comment Share on other sites More sharing options...
hoseinasadi Posted December 19, 2013 Author Share Posted December 19, 2013 (edited) Well VRay is energy conserving; the more reflective a surface is, the less diffuse value it has. You need something for it to reflect, rather than just black. so if i just add-in a sky into environment slot the black areas will reflect the sky ? basically im trying to create a kitchen floor that's partially wet ~ Edited December 19, 2013 by hoseinasadi Link to comment Share on other sites More sharing options...
CJI Posted December 19, 2013 Share Posted December 19, 2013 Or you could put a map in the environment slot of the floor material if you just want that material to reflect it. Depends how you want the final to look. Link to comment Share on other sites More sharing options...
hoseinasadi Posted December 19, 2013 Author Share Posted December 19, 2013 ill try both methods n post results here for further inquiry, thanks for the tip. Link to comment Share on other sites More sharing options...
hoseinasadi Posted December 22, 2013 Author Share Posted December 22, 2013 Or you could put a map in the environment slot of the floor material if you just want that material to reflect it. Depends how you want the final to look. ive added an HDR to environment slot , however the reflections on the floor wouldnt reflect as desired, teapot tho looks fine, im lost! Link to comment Share on other sites More sharing options...
Ismael Posted December 22, 2013 Share Posted December 22, 2013 Here is a tutorial with a file you can download: http://www.cgdigest.com/vray-wet-materials/ Another tutorial:http://cgcookie.com/max/2013/11/22/photoreal-wet-asphalt-vray/ These are tutorials or scene file which you can use to study and see how somebody else went about getting realistic results: http://www.evermotion.org/tutorials/show/7900/making-interior-scene http://www.evermotion.org/downloads/show/98/exterior-scene-by-istv-n-vastag Link to comment Share on other sites More sharing options...
hoseinasadi Posted December 23, 2013 Author Share Posted December 23, 2013 thanks mate ill try them out and post results here. Link to comment Share on other sites More sharing options...
hoseinasadi Posted December 28, 2013 Author Share Posted December 28, 2013 Here is a tutorial with a file you can download: http://www.cgdigest.com/vray-wet-materials/ Another tutorial:http://cgcookie.com/max/2013/11/22/photoreal-wet-asphalt-vray/ These are tutorials or scene file which you can use to study and see how somebody else went about getting realistic results: http://www.evermotion.org/tutorials/show/7900/making-interior-scene http://www.evermotion.org/downloads/show/98/exterior-scene-by-istv-n-vastag i finally got the hold of the idea , here's an example i just made : Link to comment Share on other sites More sharing options...
