Photorealistic reflections
himanshuchoudhary
Hi there super-talented people!
I have a question. From past few days, i have been looking at a lot of glass structures for references on a project.
Whenever i see the refelctions on a cladded wall, there seems to be a certain noise/bump effect on it. here is a very good example.
http://img222.imageshack.us/img222/212/glassupfronteh5.jpg
If you notice, the wires are not reflecting throughout in a straight line over the surface, but they tend to distort a wee bit on the edges and the middle of the individual surface.
Can anyone throw some light on how do i go about to achieve something similar on huge surfaces, where the opposite side of the street appears in a similar fashion on the cladding wall?
I use Vray 2.4 and 3dsmax 2013
Cheers
Hi there - check the below links, its exactly what you need.
http://www.ramyhanna.com/2009/01/glass-reflections-its-all-about-bump.html
http://www.ramyhanna.com/2013/04/break-up-those-panel-reflections.html
OK,
Thanks Ismael, i understand the bump effect and randomising the materialbyelement part. Could you throw some more light on the bercon map part? the "bulge" effect..?
You can also select the vertex of the glass panel and apply noise modifier, with small values the glass panel will shift randomly and produce non uniform reflection.
as in real life not glass is perfect and none glass panel is placed with the same alignment.
Yup, this is my favourite thing - this works especially well in animations where the camera is moving past or over or panning around the glass - it almost ends up looking like playing cards flipping over when the reflections change from reflecting something bright to reflecting somewhere in the shade.
