paulfinch Posted September 10, 2015 Share Posted September 10, 2015 Hi all We are trying to render a crowd using the multitexture plugin to randomise clothing. However when we use VRay DR each machine assigns a different texture per bucket Is there a fix for this? Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted September 15, 2015 Share Posted September 15, 2015 Not a fix but a workaround, you could make a multisub material (or multisub texture with your clothing bitmaps loaded) and make sure the people in your crowd have different IDs? Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted September 15, 2015 Share Posted September 15, 2015 To add to Nicolai, If your clothing is it's own object and all contained in a single map, then a Material By Element modifier comes in handy.... just tell it how many IDs you want randomized and use that same number of IDs in your Vrau MultiSub Texture. It works great and won't assign differently per machine. Link to comment Share on other sites More sharing options...
braddewald Posted September 21, 2015 Share Posted September 21, 2015 Make sure your other machines have MultiTexture installed and that it's the same version. Link to comment Share on other sites More sharing options...
