samueleeckhaut Posted November 3, 2017 Share Posted November 3, 2017 Hi, I rendered a sequence, first the GI separately (IRR and LC) and afterwards the final render with the IRR and LC files loaded. Everything worked perfect, except that you can see a darker area in the color passes on my objects (right top corner, you can see the hard line on the white/red steel frame). First, I thought it was an object that this, but when I render just one frame, I don't have the problem. If a take a look to the IRR map, you can see the darker area also. Does anyone know how this could happen? Link to comment Share on other sites More sharing options...
